nanc1234
May 14, 2021Aspirant
N600 wireless dial band router WNDR3400-100NAS
Ten yr old router. How do I get it to work without plugging into Verizon router pls? Thx.
nanc1234
I need modem correct ? Yes was expecting router to access internet
antinode
May 14, 2021Guru
If you want an Internet connection, then you need an Internet
connection. That usually means an ISP. The service from some ISPs
requires a modem.
> [...] without plugging into Verizon router pls? [...]
Do you already have a "Verizon router"?
Is there some actual problem which you are trying to solve? I don't
understand what you're trying to do.
