MeANeR
Dec 06, 2017Aspirant
n600 wireless dual band router slow speeds
I been having alot issues lately with the router with providing very slow speed. I reset connections few times , talked with xfinity and everything look good on their part. Wired I get 90mbps but w...
- Dec 07, 2017
MeANeR wrote:
Im in 2 story house 5 ppl alot devicesThat is a recipe for slow wifi.
Your router dates back to 2010. It has slow wifi technology.
If you use 5 GHz for wifi clients that might be better because it has a shorter range.
Also try different wifi bands. Look for one that other people are not using.
michaelkenward
Dec 07, 2017Guru - Experienced User
MeANeR
Dec 08, 2017Aspirant
Thanks for the info. I know the router is older but didnt know is that old lmao.
Its a huge difference, my ither house I didnt had this kinda issues but was smaller house and less ool.
Make sence, I'll deffinetly look into it for a new router.
Thank you
Thank you
