Npawlicki
Jun 15, 2022Follower
N600 Wireless Dual Band Router WNDR3400
Unable to connect to a wireless network after changing wireless security settings (macOS Monterey Version 12.3.1).
When I check the settings it says “Lan IP address not found.”
1 Reply
Npawlicki wrote:
Unable to connect to a wireless network after changing wireless security settings (macOS Monterey Version 12.3.1).Which security setting? WPA?
From what to what?
Changed where? Your old router? The Mac?
When I check the settings it says “Lan IP address not found.”What says that? A browser on the Mac? A wifi device?
