bruceettenberg's avatar
Mar 31, 2016
N600 WNDR3400v2 apple airplay having freezing issues
Streaming video from my Macbook air to apple tv in my den, running Apple OS 10X has freezing issues. Using the macbook without airplay streams video very well, but has intermittent freezing while usi...
  • ElaineM's avatar
    Apr 01, 2016
    Hi bruceettenberg Which signal you're using to connect your Macbook air?
    Make sure that there are no other wireless devices that may interfere the wireless signal.
    Check if adjusting the MTU will help.
