Gamebuster
May 15, 2016Follower
N600 WNDR3400v2 wireless not working but ethernet does?
So I have had this n600 router for a couple of years. I have only recent just had this problem. The wireless internet is discoverable by all my devices but nothing will connect to it. I updated all f...
- May 19, 2016
ElaineM,
Yes, I did reset the router and it seems to be working.
Thank you!
efrost
May 18, 2016Aspirant
Wondering if you figured out a solution to this? I am having the exact same issue with my router.
