Wyzard
Jul 21, 2015Aspirant
N600 WNDR3400V2
When I hook up my computer (desktop) to my modem (hard wired) I get about 300mbps. When I hook up my computer to my router (hard wired) I only get around 92mbps. When I log into the netgear genie it ...
- Jul 24, 2015
According to the manual for the WNDR3400v3 all ports, both LAN and WAN are rated at 10/100 Mbps.
From Page 108;
LAN
10BASE-T or 100BASE-Tx, RJ-45
WAN
So you can not exceed that rate where a wired connection is needed, including from the modem to the router.
You would need a gigabit router to achieve your full ISP throughput, anything from a WNDR3700 upwards in thge range.
michaelkenward
Jul 17, 2022Guru - Experienced User
Rather the hitching a ride on an old discussion that hasn't been touched for seven years, you might do better to start a new discussion.
If you do that, you should also tell people which devices you own. "N600 Dual Band Wireless Router and I have it connected to a AC1750 Mesh Extender" tell us nothing about the equipment you own, beyond them being slightly old. N600 and AC1750 are indicators of wifi technology. Netgear has made dozens of devices with those specifications.
vondoom2
Jul 17, 2022Tutor
Thanks, I'll start a new topic.
