Wyzard
Jul 21, 2015Aspirant
N600 WNDR3400V2
When I hook up my computer (desktop) to my modem (hard wired) I get about 300mbps. When I hook up my computer to my router (hard wired) I only get around 92mbps. When I log into the netgear genie it ...
- Jul 24, 2015
According to the manual for the WNDR3400v3 all ports, both LAN and WAN are rated at 10/100 Mbps.
From Page 108;
LAN
10BASE-T or 100BASE-Tx, RJ-45
WAN
So you can not exceed that rate where a wired connection is needed, including from the modem to the router.
You would need a gigabit router to achieve your full ISP throughput, anything from a WNDR3700 upwards in thge range.
Wyzard
Jul 24, 2015Aspirant
The screenshots are showing for me.....wan = 100M/Full. How do I change it to 1000M/Full?
Babylon5
Jul 24, 2015NETGEAR Employee Retired
From Page 108;
LAN |
10BASE-T or 100BASE-Tx, RJ-45 |
WAN |
