Iggy2005
Oct 23, 2023Follower
N600. WNDR3700-100NAS
My router shows 5G but I can not connect to my system I only show I’m on net gear 16 ?
michaelkenward
Oct 23, 2023Guru - Experienced User
Do you mean that you cannot connect a device to the wifi from the router?
What are you trying to connect?
What happens when you try?
Is netgear16 the SSID that you are trying to connect to?
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
By the way, the WNDR3700 dates back to 2009, with technology from that era. Nothing wrong with that, but don't expect wifi heaven.
microchip8
Oct 23, 2023Master
Your router is ANCIENT! Many generations behind! Time to update to current standards!
