hhp94001's avatar
hhp94001
N600 WNDR3700v4 Wired Speed
Hello,
I am new to this forum.  Please help with my questions below.
I recently upgraded my internet speed service to 500 Mbps but I noticed that my computer speed test only showed 320 Mbps (using fast.com).  The computer is currently connected to the WNDR3700v4 N600 router.
When I connected the computer directly to the modem, I was able to see a speedtest at 520 Mbps.
This is a wired connection and I do not know why my speed dropped from 520 to 320 when the computer is connected through the router.  I confirmed that my router has the latest firmware (V1.0.2.102).
I am not sure if there is something wrong with my setup.  I tried to call Netgear but they requested a fee to troubleshoot the product.
Did anyone experience what I have here?  Is it normal for my "wired" speed to be only 300 Mbps on this router model?
Thank you in advance for your help !!
HPP
  • plemans's avatar
    the WNDR3700 was a pretty rock solid router when it released. But that was 11 years ago. It tested to hit speeds of around 400mbps over a hardwired connections.
    (see smallnetbuilder: https://www.smallnetbuilder.com/wireless/wireless-reviews/30925-start-your-buying-netgear-wndr3700-reviewed?showall=&start=2
    You might be able to get a little more performance out of your wired connection by factory resetting and then during the install make sure to leave any extra features like qos, traffic monitoring, access controls, parental controls, or any other extra feature disabled.
    With a 500mbps connection, I'd look at upgrading the router regardless to utilize the connection. Its wireless was great at the time it came out but again, 11 years ago. There's much better speeds, performance now.
    • hhp94001's avatar
      hhp94001
      Thank you for the quick replies!!
      It sounds like there is nothing wrong with my router, it is just old?
      I assume I should be able to get higher wired speed based on the Router description (Gigabit router).
      Do you have a recommendation for a new router that would have no problem handling 500 Mbps? or higher?  thanks
      HHP
      • plemans's avatar
        It is a gigabit router but it was released when gigabit was just gaining traction and devices weren't maxing out gigabit connections. That's why i linked to the tested speeds on it.
        I could recommend all kinds of routers but we'd need more details to help.
        Home size?
        What is the home made of?
        What are you using it for? (gaming, streaming, etc)
        Budget? (because its pointless to recommend a $600 AX router if the budget isn't there)
        In terms of single router AC solutions, I'd go with the R7800
        for mesh systems, I'm a fan of the orbi 40 and 50 series of mesh routers/satellites
        If you're looking at AX devices, then budget gets even more important as they're a bit more expensive.
        Plus you're looking at a time when routers are at a premium because of shut downs from covid and an increase in the work from home movement.
