hhp94001
Jan 18, 2021Aspirant
N600 WNDR3700v4 Wired Speed
Hello, I am new to this forum. Please help with my questions below. I recently upgraded my internet speed service to 500 Mbps but I noticed that my computer speed test only showed 320 Mbps (...
hhp94001
Jan 19, 2021Aspirant
In my current set up, although the router offers wifi function, I do not really use this function. Instead, I use the router to feed 2 hot spots for fist & second floor (Ubiquity - https://www.amazon.com/gp/product/B016K4GQVG/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1)
Since I do not really use the "wifi" function of the router, should I get a dedicated router alone (w/o wifi function)? or it is not worth it?
thanks for sharing the link below.. I do not know much about router in general (ie. AX vs. AC). The website has interesting reviews. Will review more.
HHP
Jan 19, 2021Guru - Experienced User
If you're only using it for the wired connection and are already using ubiquiti, I'd check out a edgerouter from ubiquiti. Its not a netgear device but I've heard great things about it.
