Mgcaekdb
Jan 20, 2017Aspirant
N600 won't go over 50mbps
I just upgraded my internet connection from a max of 30mbps to a max of 100mbps. When I do speed tests now I can't get over 50mbps. I have upgraded the firmware on my router but it didn't help. Can an...
- Jan 20, 2017
The netgear r6400 or better depending how big your home is and how much you want to pay the r6400 is ac1750 router 400 mbis on 2.4 ghz n band and 1.3ghz ac on the 5 ghz band for around the 150 dollar or below mark no need for r8500 unless you have need of its power.
TheEther
Jan 20, 2017Guru
Are you getting these results with a wired or a wireless device? If wireless, are you testing at 2.4 GHz or 5 GHz? What kind of device is it? Provide the model number and/or Wi-Fi specs, if possible.
