jmartin3rd
Feb 07, 2018Aspirant
N750 / WNDR 4000 unable to sign in
I just accepted a firmware install from NetGear for my router. I received a message stating that the router was connected to another IP address and if I wanted to disconnect that IP address in order...
- Feb 07, 2018
Ended up doing a complete factory reset. Resolved the issue
antinode
Feb 07, 2018Guru
> I just accepted a firmware install from NetGear for my router. [...]
Firmware version?
> ERR_CONNECTION_REFUSED
https://community.netgear.com/t5/x/x/m-p/1502779
- jmartin3rdFeb 07, 2018Aspirant
I have no idea. I didn't see or didn't take note of a version listed when I performed the upgrade. I can't get into the router's login screen to check.
I am able to access the internet, however.
When I check my TCP/IP setting, it does say Router is using 192.168.1.1. I'm just not able to access the login screen using that same address.
- antinodeFeb 07, 2018Guru
> when I performed the upgrade. [...]
Ah. One of the advantages of manually downloading and applying an
update is that that scheme gives you a durable record of what you got.
If the easy/automatic scheme fails, it eats all the evidence.
In the words of the emminent Abraham Van Helsing, M.D., D.Ph.,
D.Lit., etc., etc., "Remember, my friend, that knowledge is stronger
than memory, and we should not trust the weaker."
Yup. Probably only the web server gets whacked.
If the new firmware makes it impossible to reach/use the normal
Firmware Update page, then the only way to recover may be to use the
TFTP scheme to load a different (presumably older) firmware image:
https://community.netgear.com/t5/x/x/m-p/1502275- jmartin3rdFeb 07, 2018Aspirant
Thanks for sending that link - it's the exact same experience that I'm having.
