Jjal
Mar 23, 2024Aspirant
N750:WNDR4300v2 Wifi
My N750 Router will suddenly stop broadcasting either 2G or 5G. The function lights remain on showing the channel is active, but the signal is not there. Is there fix? Could this be the Interne...
michaelkenward
Mar 23, 2024Guru - Experienced User
Jjal wrote:
Could this be the Internet provider?
The Internet service provider has no control over your wifi. That is down to the router.
The ISP just provides the Internet connection that your router then turns into something useful.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Start by checking the section in the manual Troubleshoot With the LEDs.
