srobertss
Dec 21, 2015Aspirant
n90 dual band router, model r4500 stopped working for android phones
we've been using this router for at least a year with no problems. suddenly (last week) it stopped working with our two android phones. all other devices are fine: computer, tablet, roku. the ph...
- Jan 11, 2016
im not sure why my earlier reply wasnt posted but yes, i did try that. but i found the solution. i bought a new router and it works! i guess as these things age, they can work on some devices and not others.
srobertss
whoops, i meant n900 and i should have included this info: firmware version is 1.0.0.4_1.0.3. Im assuming this is the latest, though when i tried to update on the netgear genie it said it couldnt connect.
and i also tried changing the security settings, but it didnt help.
- srobertssDec 21, 2015Aspirant
i keep thinking of things i left out! sorry to be such a flake. both phones detect the network and appear to be connected. but there is no connectivity. and i did turn the router off and then on again.
- DarrenMDec 23, 2015Sr. NETGEAR Moderator
Hello srobertss
Have you tried to tell the phones to forget the network and then reconnect to it?
DarrenM
- srobertssJan 11, 2016Aspirant
