cocoakitten
Feb 05, 2016Aspirant
[N900 / WNDR4500] - Can't use/access some services/web sites even after reset to factory settings
Hello, I just moved to a new home; my old cable modem was damaged during the move and so I had to replace it (same manufacturer, newer model). The problem started then with the messeging se...
- Retired_MemberFeb 15, 2016
go to setup....internet setup.....select use PC MAC Address....reboot modem and router
storm1985
Feb 07, 2016Prodigy
Try to reset network settings on your phone
- Retired_MemberFeb 07, 2016
I heard the 4500 is @ EOL meaning End of Life. I don't know which version or if all versions are EOL. My point is return it so you don't get stuck with a device which is no longer be supported.
- cocoakittenFeb 14, 2016Aspirant
Hi searay,
Thank you for your reply. I don't think I can return it as it's been with me quite a while now :-) Perhaps it's time for me to research for a new one *sigh*
Hi storm1985,
Thank you for your reply and apologize for my late response (I was away and didn't have the chance to check back). I actually tried resetting the network on my phone when I reset the router. Sadly, it didn't work.
