cocoakitten
Feb 05, 2016Aspirant
[N900 / WNDR4500] - Can't use/access some services/web sites even after reset to factory settings
Hello, I just moved to a new home; my old cable modem was damaged during the move and so I had to replace it (same manufacturer, newer model). The problem started then with the messeging se...
- Retired_MemberFeb 15, 2016
go to setup....internet setup.....select use PC MAC Address....reboot modem and router
storm1985
Feb 07, 2016Prodigy
Try to reset network settings on your phone
cocoakitten
Feb 14, 2016Aspirant
Hi storm1985,
Thank you for your reply and apologize for my late response (I was away and didn't have the chance to check back). I actually tried resetting the network on my phone when I reset the router. Sadly, it didn't work.
