R47
Nov 20, 2017Aspirant
N900 not allowing samsung Bluray player to access
My new Samsung Blueray player can see the Wifi and i can input my security code but it won't connect. I've tried everything with samsung support and we can't get it to connect. I haven't had issues w...
- Nov 27, 2017
Hi R47,
Check the security option that BluRay supports. Lower down the security option of BluRay does not support WPA2.
michaelkenward
Nov 21, 2017Guru - Experienced User
These things usually come down to the settings on the BluRay player. These "smart" devices are actually very dim. You might do better to find a forum where people talk about Samsung's BluRay players.
I had hell's own trouble getting my Samsung BD-F6500 to work over wifi. Fortunately, I had already decided to go down the Powerline Ethernet route and now use the LAN feature.
R47
Nov 21, 2017Aspirant
Thanks for the response. I went through the aettings with the Samsung support guy. I'm thinking it's something with the router
