CyberSurfer's avatar
Jan 10, 2021
N900 with Arris Modem speed capped
Hi all,   Hoping some of you fine folks can help me out. Having an issue with my N900 providing >100Mbs while the Arris router from Spectrum is providing <400Mbs. The N900 is a WNDR4500v2 with the...
  • plemans's avatar
    Jan 11, 2021
    What arris do you have?
    Have you checked the cable? make sure its cat5e or >.
    swap it out if you are questioning it at all
