CyberSurfer
Jan 10, 2021Tutor
N900 with Arris Modem speed capped
Hi all, Hoping some of you fine folks can help me out. Having an issue with my N900 providing >100Mbs while the Arris router from Spectrum is providing <400Mbs. The N900 is a WNDR4500v2 with the...
- Jan 11, 2021
What arris do you have?
Have you checked the cable? make sure its cat5e or >.
swap it out if you are questioning it at all
CyberSurfer
Jan 12, 2021Tutor
Plemans,
So swapping out the cable to a Cat6 seemed to do the trick. My desktop which is wired is now reporting close to the 400Mbs expected. My wireless 5g doubled, but is hovering around 180/190 Mbs. Any idea why it might not be getting the full 400Mbs on 5g? The 2.4 is even worse at only 60Mbs, but I don't know what speed 2.4Ghz should top out at.
Thanks again for the help and I marked that as the answer. If you have further insight on the wireless speed it be appreciated, but you certainly moved me forward.
Could it be that the NetGear n900 is splitting the 400Mbs between the 5Ghz, 2.4 Ghz, and the guest network?
Jan 12, 2021Guru - Experienced User
glad it fixed it.
Your wireless speeds are actually pretty awesome for that device.
Its a n900 device and a bit older one at that.
Some AC devices won't max out 400mbps over 5ghz. Your almost 200mbps is pretty darned good for 5ghz with that router.
And 2.4ghz is much much slower than 5ghz. hitting 60mbps is basically when AC devices hit over 2.4ghz and you're on a wireless N router.
