birdie377
Oct 12, 2015Aspirant
NAT Loopback : Low bandwidth
Hi there, I have a WNDR4500 first generation as my lan router, behind the internet gateway. There is a server on the LAN and some clients (smartphones, computers) access it from both LAN and WAN...
- Oct 27, 2015
Based from engineering, the only way to get this working is through the use of IP address.
There will be no firmware updates to correct this since the device is already EOL.
I apologize for any inconvenience this may have caused you.
ElaineM
Oct 13, 2015NETGEAR Employee Retired
Welcome to the community, birdie377
What is the exact changed you made on the router to get full network speed?
What's the firmware version loaded on your router?
birdie377
Oct 20, 2015Aspirant
Hi, - To get full speed, the client connects to the server by using the server LAN IP address. The problem reported is when the public domain name of the server is used which requires the internet router to loopback the traffic to the server LAN IP address. - Firmware is 1.0.1.36_1.0.63. If you were considering asking to upgrade the firmware, may I ask you to please ask only if there is updates to the NAT loopback function. I would rather not update for the sake of having the latest version. Thank you.
- ElaineMOct 21, 2015NETGEAR Employee Retired
I would like to confirm that the slow down happens when accessing the server from the LAN side, correct?
If someone from outside your network tried accessing the server, will you experience the same?
And when you say bandwidth very low, is this the Internet access? Or it is something else?
Is the slow down happening on the wireless or it doesn't matter?
Did you check all your DNS settings on the server side?
By the way, what kind of server do you have?
- birdie377Oct 22, 2015AspirantI would like to confirm that the slow down happens when accessing the server from the LAN side, correct? => Yes, when the client uses the domain name. This means traffic will go to the WAN and the router is supposed to find out that the WAN IP is its own WAN IP and then route back to the server LAN IP address following port forwarding rules. If someone from outside your network tried accessing the server, will you experience the same? => the same client connects from the WAN too and gets the same kind of transfer speed as when it is using the domain name to reach the server from the LAN And when you say bandwidth very low, is this the Internet access? Or it is something else? => About the same as the uplink bandwidth Is the slow down happening on the wireless or it doesn't matter? => Occurs with both Ethernet and Wireless Did you check all your DNS settings on the server side? => Yes By the way, what kind of server do you have? => Synology running DSM 5.1. Clients are using Cloud Station (similar to drop box) or, for mobile devices DS Cloud and DS File.
- ElaineMOct 23, 2015NETGEAR Employee Retired
Thank you for the details provided.
I have forwarded this to our engineering team for verification and will give you an update as soon as I have a response.
