birdie377's avatar
birdie377
NAT Loopback : Low bandwidth
Hi there,   I have a WNDR4500 first generation as my lan router, behind the internet gateway. There is a server on the LAN and some clients (smartphones, computers) access it from both LAN and WAN...
  • ElaineM's avatar
    ElaineM
    Oct 27, 2015
    Based from engineering, the only way to get this working is through the use of IP address.
    There will be no firmware updates to correct this since the device is already EOL.
    I apologize for any inconvenience this may have caused you.
