LouBu
Jul 17, 2016Aspirant
Need a router which allows Wifi to be turned OFF
Hi, I need a router that has a Wifi on/off switch that will allow me to use it wired. Does the N300, or one of the others, have a Wifi on/off switch? Thanks, Louise.
Retired_Member
Jul 17, 2016Pick any router, and then go to the "Downloads" tab at the top of this page. Enter the model number and then read the manual.
N300 is not a model #
VE6CGX
Jul 17, 2016Master
Any router has that ability in their f/w.
- aalexandrebetaJul 23, 2016Master
All router have a kill switch to turn off wifi!
Push the switch and that's it!
- ElaineMJul 25, 2016NETGEAR Employee Retired
- aalexandrebetaJul 25, 2016Master
I think every router I had and currently using has a switch to turn on and off wifi signal!
- LouBuJul 25, 2016Aspirant
BT Hubs dont have a physical wifi on/off button. You can only access it by logging into an online app.
Thanks ElaineM. I'll mark your reply as the solution :)
