LouBu's avatar
LouBu
Need a router which allows Wifi to be turned OFF
Hi, I need a router that has a Wifi on/off switch that will allow me to use it wired. Does the N300, or one of the others, have a Wifi on/off switch? Thanks, Louise.
  • ElaineM's avatar
    ElaineM
    Jul 25, 2016
    LouBu You may want to check the latest router model, R7800. It has a WiFi On/Off button.
