caspersgrin
Nov 21, 2020Aspirant
Need a wifi to usb product recomendation
I have an Xfinity gateway router along with a Netgear AC1750 Dual Band Mesh Extender. Prior to this ne setup, I was using an Apple Airport network that was physically plugged into my Xfinity router,...
michaelkenward
Nov 22, 2020Guru - Experienced User
caspersgrin wrote:
Will any WiFi to USB or WiFi to ethernet adapter work just fine? What my best choice?
I still don't know what a "USB or WiFi to Ethernet adapter" might be. You may have just invented a useful device.
To recap what I said before, most people with Netgear stuff use ReadySHARE to share a printer in the network.
You plug the printer into a USB port on the router or wifi extender. You can then access the printer with anything that uses the router/extender for wifi.
Then again, if this is an Ethernet printer, can't you just connect it to the network and access it from there?
Why not read the manual and/or data sheet for something like the EX6200V2 WiFi Range Extender?
As the data sheet says:
"Print documents & photos to any USB printer
connected to the WiFi Range Extender."
I didn't pick that one for any particular reason – I don't own one – but to show you what you can get hold of in the way of Netgear devices. I do use an R7800 router to share a USB printer.
A lot may depend on your "Xfinity gateway router", which sadly is an unknown box to anyone reading these messages. So who know what will work with it?
antinode
Nov 22, 2020Guru
> [...] I have a legacy HP LaserJet 3390 printer with both a USB and LAN
> interface. [...]
Where "LAN" means (to you) "Ethernet"? (Your wireless stuff is also
part of your Local-Area Network.)
> [...] I need to connect it wirelessly to my WiFi network. [...]
An Ethernet cable would be simpler, of course. Which interface on
the printer were you using before, Ethernet or USB?
> [...] Will any WiFi to USB or WiFi to ethernet adapter work just fine?
Dreamer. To use the USB interface, what you'd want is called a
"print server". (A "wireless print server", if you want a wireless
network connection.) Whether that would support the scanner features is
not immediately obvious.
Most USB-wireless gizmos out there are intended for use with a
computer, not a printer. Very different software environments. Your
printer won't know how to deal with one.
More likely to be suitable would be a wireless bridge, which would
provide a wireless-to-Ethernet connection. Some Netgear routers offer a
wireless-bridge-mode option, but I'd guess that a purpose-built wireless
bridge would be cheaper.
Read it again.
> [...] You may have just invented a useful device.
Someone might have.
> A lot may depend on your "Xfinity gateway router", [...]
Not really. It's a printer-to-network question; the details of the
network are generally inconsequential (other than wired v. wireless).
