Anesinano
Oct 21, 2020Aspirant
Need advice please
Should I get orbi ax4200 or fork over the extra $ and get the ax6000? My house is 1700sqft, got a basement where my isp modem is.. got century link 1 gb speed. Is the ax4200 sufficient enough? Will ...
- Oct 22, 2020
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
Anesinano
Oct 22, 2020Aspirant
It’s not brick, got a basement(where the modem is), then 1st floor(living room) and 2nd floor upstairs. The house is 1700sqft.
Well when I do a speed test in the basement on my phone I would get faster dl and ul speed(maybe 200mbps) but in the living room maybe 70mbps on the phone. I just didn’t think it would be that low for having fiber gig..I can’t move the modem upstairs since they drilled the whole for the fiber wire into my basement..i got centurylink, modem is actiontec c3000a and I’m not sure if the ax4200 or the 6000 would be better or what not..appreciate it thanks for the reply
michaelkenward
Oct 22, 2020Guru - Experienced User
and
- AnesinanoOct 22, 2020AspirantThank you will look into it, much appreciated, thanks again
