daveharriett
Apr 22, 2020Tutor
Need an ethernet port on other side of house from router
I am adding an additional NVR security system on the opposite side of the house from my router. It requires an ethernet port for connectivity. I have had a Netgear EX6150 AC1200 WIFI extender for...
- Apr 23, 2020
Powerline Ethernet if you domestic mains wiring is up to it.
Does just what you want for many people.
michaelkenward
Apr 23, 2020Guru - Experienced User
- daveharriettApr 23, 2020Tutor
I just ordered the Netgear Powerline 2000 + extra outlet. I hope that does what I'm looking for. Thanks for all the help with alternatives.
Dave
- antinodeApr 23, 2020Guru
> I just ordered the Netgear Powerline 2000 + extra outlet. [...]
Did you order one of them, or did you order the pair of them that you
will need? (What, exactly, comes in the box?)- daveharriettApr 24, 2020Tutor
I ordered the pair. https://www.bestbuy.com/site/netgear-powerline-2000-extra-outlet/6203586.p?skuId=6203586
- michaelkenwardApr 24, 2020Guru - Experienced User
I hope that works out. Good luck.
The PLP2000 is the latest modem and has LAN ports at 1000 Mbps, way faster than your antique router, so the plugs shouldn't get in the way as long as your mains circuit cooperates.
It looks like the plugs you have ordered have the advantage of a second LAN output on the "guest" plug, which may come in useful.
The minimum number in the box is two plugs. Netgear doesn't sell singletons. Fortunately, other brands do sell one offs and these happily coexist with Netgear's plugs.
You need only one plug connected to the source router. You can then add other plugs to its network.
