daveharriett
Apr 22, 2020Tutor
Need an ethernet port on other side of house from router
I am adding an additional NVR security system on the opposite side of the house from my router. It requires an ethernet port for connectivity. I have had a Netgear EX6150 AC1200 WIFI extender for...
- Apr 23, 2020
Powerline Ethernet if you domestic mains wiring is up to it.
Does just what you want for many people.
antinode
Apr 23, 2020Guru
> I just ordered the Netgear Powerline 2000 + extra outlet. [...]
Did you order one of them, or did you order the pair of them that you
will need? (What, exactly, comes in the box?)
daveharriett
Apr 24, 2020Tutor
I ordered the pair. https://www.bestbuy.com/site/netgear-powerline-2000-extra-outlet/6203586.p?skuId=6203586
- michaelkenwardApr 24, 2020Guru - Experienced User
That's fine. Netgear does not sell single plugs so that's a red herring.
A further thought, newer Powerline plugs can turn up with "sleep mode" (power saving) activated by default. Don't panic if you see signs of that. Drop by the Powerline bit of this place. There's an easy answer, but don't worry about that until it happens.
- daveharriettApr 24, 2020Tutor
The Netgear Powerline 2000 worked like a charm. My NVR is getting great speed. Thanks
