daveharriett
Apr 23, 2020Tutor
Need an ethernet port on other side of house from router
I am adding an additional NVR security system on the opposite side of the house from my router. It requires an ethernet port for connectivity. I have had a Netgear EX6150 AC1200 WIFI extender for...
- Apr 23, 2020
Powerline Ethernet if you domestic mains wiring is up to it.
Does just what you want for many people.
daveharriett
Apr 25, 2020Tutor
The Netgear Powerline 2000 worked like a charm. My NVR is getting great speed. Thanks
michaelkenward
Apr 25, 2020Guru - Experienced User
Great. Another convert.
When it works, Powerline Ethernet is a simple alternative to running wires around the place, a possible cause of marital grief.
