NancyLee
May 24, 2016Aspirant
Need help connecting my samsung galaxy 6 to wifi
I have not been able to connect my phone to the wifi, I am out in the country & I have little service on my phone. I have gone through the steps to do it with no luck, tried to get help through veri...
- May 24, 2016
Do you see SSID of your router with Galaxy? If you do, select that SSID and connect, then you will be asked passphrase, etc. Answer the questions, then it should connect.
