Vsimpson
Nov 26, 2021Follower
Need help connecting to new modem
Hi can anyone talk me thru connecting an old netgear n600 to my new spectrum modem?
michaelkenward
Nov 27, 2021Guru - Experienced User
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
Don't expect a lot from an WNDR3400. If your Internet speed is faster than 100 Mbps, then you should not use it.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet. It also slows down whatever is going on in your local network. Newer devices support 1000BASE-TX.
