testeri1
Nov 17, 2024Aspirant
Need help optimizing speed
I have a netgear cm1000 modem and a netgear xr1000. I picked up 1200 gbps from xfinity and the router is only getting 460mbps download and 24 upload The modem is hardwired and the modem is hardwire...
michaelkenward
Nov 17, 2024Guru - Experienced User
These are speeds measured with wired connections?
Did you reset and reconfigure these devices for the new service?
The modem is hardwired and the modem is hardwired to the router.Is this normal?
I don't understand. The router should be wired to the modem. It can't work otherwise.
Just another user with time on their hands.
