varxtis
Jan 10, 2016Aspirant
Need help port forwarding for XBox One remote Streaming
I have an R6200v2 Router and need help with port forwarding. I came accross this set of instructions to setup port forwarding to stream XBox One Streaming remotely from anywhere http://kinkeadtech....
- Jan 10, 2016
Hi @varxtis,
You should input them in the field for External Starting Port and External Ending Port. You will need to forward them individually except for the range of 49000-65000. The steps are as follows.
1. Create a Service Name (It could be anything but you may not be able to use the same service name twice. Ex. XBOX1, XBOX2, and so on.)
2. Select the service type (TCP, UDP, or Both)
3. Input 5050 for both External Starting Port and External Ending Port.
4. Select the IP address of your XBOX.
5. Select Apply.
6. Do the same for the other port numbers. For the range, use 49000 for the External Starting Port and use 65000 for the External Ending Port.
Dexter
Community Team
DexterJB
Jan 10, 2016NETGEAR Moderator
Hi @varxtis,
You may refer to the link below for the steps on how to setup port forwarding for your router. Please make sure you have the required information like the IP address of your the device that you will forwarding (XBOX), the port number/s, and protocol (TCP, UDP, TCP/UDP).
http://kb.netgear.com/app/answers/detail/a_id/24046
Dexter
Community Team
- varxtisJan 10, 2016Aspirant
I appreciate the reply, but Im confused on where the numbers 5050, 4838, and 49000-65000 fit in.
- DexterJBJan 10, 2016NETGEAR Moderator
Hi @varxtis,
5. Select Apply.
Dexter
Community Team
- varxtisJan 11, 2016Aspirant
Thank you very much!!
On the Range Service (49000-65000), I get the following error:
The specified port(s) are being used by other configurations. Please check your configurations of USB Readyshare, Remote Management, Port Forwarding, Port Triggering, UPnP Port Mapping table, RIP, and Internet connection type.
Any suggestions/ideas on what might be causing this by default.
EDIT: Found where they're being used... under UPnP. There seesm to be a LOT of them. Many are for the same IP Addresses. What is UPnP. is there a different round-about way of establishing the ranged ports for port forwarding. Also, for my clarification. Im supposed to be creating these new services under Port Forwarding and not Port Triggering, right?
