Need help port forwarding for XBox One remote Streaming
- Jan 10, 2016
Hi @varxtis,
You should input them in the field for External Starting Port and External Ending Port. You will need to forward them individually except for the range of 49000-65000. The steps are as follows.
1. Create a Service Name (It could be anything but you may not be able to use the same service name twice. Ex. XBOX1, XBOX2, and so on.)
2. Select the service type (TCP, UDP, or Both)
3. Input 5050 for both External Starting Port and External Ending Port.
4. Select the IP address of your XBOX.
5. Select Apply.
6. Do the same for the other port numbers. For the range, use 49000 for the External Starting Port and use 65000 for the External Ending Port.
Dexter
Community Team
Hi @varxtis,
UPnP allows some of your devices to discover and communicate with other connected devices within the network. You can disable UPnP then perform port forwarding. Yes, they should be under Port Forwarding not unless it is specified by the application to be triggered.
Dexter
Community Team
Thank you again.
Last question:
If I do disable UPnP to do the port forwarding, would I reactivate it after Ive established the port forwarding? I use my tablet and phone a lot to manage my computers and transfer files. Idk if doing this would be worth messing up how my devices communicate with the network.
