Roseman
Jun 09, 2016Aspirant
Need help with WNDR3700v3 and Seagate Slim Backup Plus 1TB
I own a WNDR3700v3 and am trying to use a just purchased Seagate Slim Backup Plus 1TB, USB. The WNDR3700v3 has the latest software (V1.0.0.38_1.0.31), and the Seagate does not require any drivers. I...
- Jun 09, 2016
Router's main purpose is routing so users can share Internet and files between themselves. Likes of USB port or eSATA port
is just a secondary thing. USB 3 has shielding problem and known to have inherent noise problems. When some people call USB
drive attached to router a NAS, I have to wonder. Real NAS is a computer on it's own with it's own OS which performs many
different tasks. I just leave 64GB flash drive on USB port as a scratch pad. I have Synology NAS running 24/7 .
It does not mean non-listed drives won't work. There will more which will work, If one want to use a USB attached drive as storage
facility better have self contained 2 bay enclosure which will do Raid 0/1 or JBOD set up. I had 3700 LONG time ago. I favorite f/w
for it was Trondah's OpenWRT with Luci GUI. I go thru average 2 routers a year getting newer ones for testing and review at
no cost to me. Every one of them worked. Some are easier to manage and control, some are little more difficult. But all worked for me.
VE6CGX
Jun 10, 2016Master
Here I see so many routers and what not quite old, couple generations past on technology evolution. On the Netgear line up one should be considered minimum is probably R7000 for now. Anything below should be off the list as far as I am conccerned. I have quite a few buddies still
actively working in the field but I am long retired after 40 odd years in the related field. I am on the worng side of 70 closing on 80, LOL! R7000
has a few 3rd party f/w choices. Xvortex, dd-wrt, Shibby's ., etc.
Roseman
Jun 10, 2016Aspirant
Thanks, VE6CGX . I appreciate the thoughts. And I am not far behind you in the age!
