Roseman
Jun 08, 2016Aspirant
Need help with WNDR3700v3 and Seagate Slim Backup Plus 1TB
I own a WNDR3700v3 and am trying to use a just purchased Seagate Slim Backup Plus 1TB, USB. The WNDR3700v3 has the latest software (V1.0.0.38_1.0.31), and the Seagate does not require any drivers. I...
- Jun 09, 2016
Router's main purpose is routing so users can share Internet and files between themselves. Likes of USB port or eSATA port
is just a secondary thing. USB 3 has shielding problem and known to have inherent noise problems. When some people call USB
drive attached to router a NAS, I have to wonder. Real NAS is a computer on it's own with it's own OS which performs many
different tasks. I just leave 64GB flash drive on USB port as a scratch pad. I have Synology NAS running 24/7 .
It does not mean non-listed drives won't work. There will more which will work, If one want to use a USB attached drive as storage
facility better have self contained 2 bay enclosure which will do Raid 0/1 or JBOD set up. I had 3700 LONG time ago. I favorite f/w
for it was Trondah's OpenWRT with Luci GUI. I go thru average 2 routers a year getting newer ones for testing and review at
no cost to me. Every one of them worked. Some are easier to manage and control, some are little more difficult. But all worked for me.
ElaineM
Jun 14, 2016NETGEAR Employee Retired
How many files do you have?
It might be due to indexing, it can only accomodate 25k files.
- RosemanJun 14, 2016Aspirant
Thanks, ElaineM
maybe 50 files is all. I did get a response from netgear through their website. Guess it was not as robust as an average consumer whould have thought
"Thank you for reaching out. The USB HDD & Flash Drives listed on the compatibility list for WNDR3700v3 are the only ones compatible to use as a ReadyShare Media server. Unfortunately, your Seagate Slim Backup Plus is not compatible with our router which would result to issues with connectivity & stability when connecting it to your router.
Best Regards,
NETGEAR Team"
- VE6CGXJun 14, 2016Master
ONLY ONEs compatible? Seriously you mean Netgwear tested ALL the hard drives floating out there?
