MicFirestone
Jan 17, 2022Follower
Need N750 Settings Info
Hi all, I have replaced my aging N750 with a new NightHawk 3 station mesh system (working very well). We moved and could not get to my old N750 router before I received and set up my new NightHaw...
Jan 18, 2022Guru - Experienced User
You should be able to disconnect the N750 from the modem and router and connect a device directly to it.
when you do, try access it using its ip address.
