MicFirestone
Jan 17, 2022Follower
Need N750 Settings Info
Hi all, I have replaced my aging N750 with a new NightHawk 3 station mesh system (working very well). We moved and could not get to my old N750 router before I received and set up my new NightHaw...
michaelkenward
Jan 18, 2022Guru - Experienced User
MicFirestone wrote:
Now, I don't have the N750 connected to a modem, but should that be necessary? I just want to access the setup of the N750 to see what port and portforwarding (and a few static IP assignments) so that I can move them over to the NightHawk. Any suggestions appreciated.
What N750 device do you actually own? (N750 is a wifi speed indicator, not a modem number.)
Your footer says DGND4000. But that is a modem/router and you would not normally connect that to a modem.
This could be important. Modem/routers and routers usually have different default IP addresses.
wcalifas
Jan 19, 2022Prodigy
Try clearing the cache or history on whatever browser you're using. You can also just try a different browser. If that doesn't work try your cell phone and use the browser on your cell phone to connect to it through its wifi signal.
