frustrated240
Aug 17, 2021Tutor
Need Netgear software that allows me to open an AcuRite Access device on my Ethernet port ?
I have an Acurite Acess device that links a weather station to the AcuRite website so they can link it to the Underground Weather wesite to monitor your home weather with. The Acess Device is Model ...
- Aug 19, 2021
Finally got it figured out and working after working with AcuRite techs. Had to get their software app so that they could speak to my devices. Now I can see my weather on "myAcurite.com app. Thanks everyone for helping me out!
Aug 17, 2021Guru - Experienced User
What modem/gateway is the router connected to?
- frustrated240Aug 17, 2021Tutor
It is attached directly to a cable that goes to a dish that goes to an independent internet service called digital technology solutions in NV.
- plemansAug 17, 2021Guru - Experienced User
seems like we run into issues all the time with broadcast internet.
A couple questions.
1. does the router work on AP (access point) mode? Reason I ask, is many times, the isp uses their own routing setup and broadcasts off that. Then when it gets to a home residence, the home router is there and you end up with a double nat. Most devices don't have an issue with it but some streaming services and IoT devices struggle with it.
2. Does your ISP have a recommended router or router setup?
- frustrated240Aug 18, 2021Tutor
I am not sure but can find out. A bit over my head to be honest. A bit of a novice with all this stuff.
It is connected via the WAN portal to a direct line to the internet Service called Digital Technology Solutions.
