frustrated240
Aug 17, 2021Tutor
Need Netgear software that allows me to open an AcuRite Access device on my Ethernet port ?
I have an Acurite Acess device that links a weather station to the AcuRite website so they can link it to the Underground Weather wesite to monitor your home weather with. The Acess Device is Model ...
- Aug 19, 2021
Finally got it figured out and working after working with AcuRite techs. Had to get their software app so that they could speak to my devices. Now I can see my weather on "myAcurite.com app. Thanks everyone for helping me out!
michaelkenward
Aug 18, 2021Guru - Experienced User
frustrated240 wrote:
Does Netgear have any kind of software that would recognize this AcuRite Access device (which links to the Acurite Weather Station) so that I can open the device on line?
You should not need any extra software. If the Weather Station is on the LAN, then whatever Acurite provides should come into play.
My weather station is a USB device that connects to the PC, I can then use a browser to connect to Weather Undrgound, if that is what you mean by "Underground Weather wesite".
As plemans implies, seems more like a network issue than the need for any fancy software.
frustrated240
Aug 19, 2021Tutor
- michaelkenwardAug 20, 2021Guru - Experienced User
That's what I'd expect. It's like the system I have. All down to the client at this end rather than the network. But your set up sounds more sophisticated than my basic kit.
Glad it worked out.
