ajm6u
May 11, 2016Aspirant
Need power adapter replacement for wndr4300v2 router
I bought the N750 wifi router not even a year ago and I believe the power adapter may have failed, since we can't get power to the router (I've tried plugging it into multiple outlets, but still no p...
- May 11, 2016
No, 12V 1A will not work. The voltage (12V) and polarity (+ and - orientation on the plug) must match on the replacement, but the amperage can be greater than needed. So, a 12V 2A would be fine.
TheEther
May 11, 2016Guru
- ajm6uMay 11, 2016Aspirant
Thank you. That's what I needed to know. Much appreciated.
