jakkwb
Jan 17, 2017Aspirant
Need RMA for router past 90 days...
Have a Walmart purchased "lifetime" warranty router, the wnr2000 n300. Internet/WAN port no longer works, detects no service at all when plugged into working service. Yes, this is past 90 days, s...
- Jan 30, 2017
Hi jakkwb,
Please try MAC spoofing.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
DexterJB
Jan 22, 2017NETGEAR Moderator
Hi jakkwb,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- jakkwbJan 25, 2017Aspirant
The WAN/internet light stays orange whenever I plug a cable into it and any of the other jacks. Each jack lights up, but the WAN/internet light stays orange.
- DexterJBJan 25, 2017NETGEAR Moderator
Hi jakkwb,
If the WAN/Internet light stays lit, that means that the port still works. Try re-flashing the firmware then reset and reconfigure the router. You can check the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
- jakkwbJan 26, 2017Aspirant
No, it is still not working. The Internet light is always yellow, it never changes to green or blue or whatever color it is supposed to be when its working.
The web page still has an X on the internet port. it does not get an IP or other information from DHCP.
I have reloaded the firmware as well as defaulted it. No change.
