SusanMarieb's avatar
SusanMarieb
Follower
Apr 23, 2021
need to temp disable 5ghz R6400v2 — AC1750 Smart WiFi Router 802.11ac Dual Band Gigabit:
I purchase the Atomismart wifi Stringlights and to install them they only work with 2ghz.  They say to disable the 5ghz mode so it can connect. then once the lights are connect re-enable the 5ghz.  I...
