Stuntman
Feb 03, 2021Follower
Need WiFi extended to new building
I am looking to try and extend the network from one building, that has fiber internet, to a new building that is about 150 feet away. This would involve having to go through a couple of walls as well...
Feb 03, 2021Guru - Experienced User
ouch. 150 ft is a good distance plus the walls. I doubt you'll find a single solution that would do it (other than burying a cable, which is a great option).
You could try a point to point system like netgears airbridge if you have a clear line of sight.
