popmanlentz
Jan 27, 2026Follower
Need Wifi in my new metal building advice
Hi, I have wifi in and outside of my house but my new 30x24 metal garage won't allow signal unless I am by the window. I am wanting to receive from outside into the inside when it's closed up. We are...
Jan 28, 2026Guru - Experienced User
If you're planning on being there a lot and this is only 50 ft, I'd take the time and trench in a underground rated ethernet cable. While it's a bit more work upfront, you'll have much better performance and its something that will last. I'd even get some cheap underground pipe to use and when you put it in, run a nylon string with it in case you ever want to upgrade. Pretty cheap to do and will be great for the future. IF that isn't possible, then I'd move to the wireless bridge option. A point to point system would be ideal
