gene4570
Apr 22, 2017Aspirant
need wiring instructions to connect to an microwave antenna isp no modum
i use a isp that is radio based i have no modum only a router - computer to router to antenna - all the wiring instructions include a modum. any help appreciated.
- Apr 23, 2017
TheEther wrote:Plug your router into that connection.
Yup. And use the Internet port.
The Installation Guide may help:
>>> WNDR3400v3 | Product | Support | NETGEAR <<<
TheEther
Apr 22, 2017Guru
Assuming that you have a WISP (Wireless ISP), there should be an Ethernet connection that they should have provided you. Plug your router into that connection.
michaelkenward
Apr 23, 2017Guru - Experienced User
