JRiv
Jul 18, 2022Follower
Net Gear AC1200 Wifi extremely slow compared to wired connection
NetGear AC1200 WIFI Cable modem Router Model # C6220 Router is on Firmware Version V1.02.11 ISP - Xfinity Ethernet connection speed test 89mbps WIFI connection speed test 4.94 Mbps My wif...
Jul 18, 2022Guru - Experienced User
but wired you still get full speeds?
If so, you can try a factory reset and see if it helps
