k4igk
Mar 20, 2022Tutor
Net Gear AC1750 R64000-100NAS Firmware V1.0.4.106
I have 300 Mbps service to my modem. I speed check directly from the modem and I get 300 Mbps, but only get 90 Mbps from any lan connection on my router. Qos speed check gives me 1.5 Mbps. Suggesti...
- Mar 21, 2022
Well I would have never guessed that two cables ( original) and substitute cable were both CAT 5. Rounded up another cable (CAT 6) and bingo success. Thank you for guiding me through this project. Now have 300 Mbps on all LAN connections. Kudos!
Mar 20, 2022Guru - Experienced User
have you checked to see if you're actually getting a gigabit connection from modem----router?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
if not, try replacing the cable between the 2.
k4igk
Mar 21, 2022Tutor
