k4igk
Mar 20, 2022Tutor
Net Gear AC1750 R64000-100NAS Firmware V1.0.4.106
I have 300 Mbps service to my modem. I speed check directly from the modem and I get 300 Mbps, but only get 90 Mbps from any lan connection on my router. Qos speed check gives me 1.5 Mbps. Suggesti...
- Mar 21, 2022
Well I would have never guessed that two cables ( original) and substitute cable were both CAT 5. Rounded up another cable (CAT 6) and bingo success. Thank you for guiding me through this project. Now have 300 Mbps on all LAN connections. Kudos!
Mar 21, 2022Guru - Experienced User
for some reason you're only pulling a 100mbps link speed from the modem.
I know you tried a different cable but was it a cat 6 cable?
k4igk
Mar 21, 2022Tutor
- plemansMar 21, 2022Guru - Experienced User
Glad it was something simple and you got it back up and working right!
You might mark it solved so others don't try to fix an already fixed issue 🙂
- michaelkenwardMar 21, 2022Guru - Experienced User
Cables have a nasty habit of failing. Usually at the most inconvenient time.
If you have ever tried to make your own cables, you can see why. Not the most foolproof design you can think of.
