Samuel0014
Jan 12, 2024Aspirant
Net Gear R6080. Cannot Connect To Wi Fi On Phone.
Hello, Brand new here. Hope you guys can help. I have exhausted other resources. Maybe my problem has nothing to do with router - I really don't know. I have a Galaxy A13 phone. I have been a...
- Jan 13, 2024
Samuel0014 wrote:
I have no idea what "telecom operator issue" means.
This is whoever provides your cell phone service.
Trying to send or receive pictures attached to text messages, as mentioned in your first message, has nothing to do with the Internet service provider or the wifi from your router.
You should be able to do that when you are nowhere near your home wifi.
michaelkenward
Jan 13, 2024Guru - Experienced User
As microchip8 says, your router has nothing to do with how your phone works.
This bit is a bity puzzling though:
Samuel0014 wrote:
BaiConnect guy said I needed wi-fi. I thought I had wi-fi through my Netgear 6080 router. When I go to Settings --> Connections --> wi-fi, it says, "Netgear 25" When I press that, it says, "Connected." But I still get message "Multi Media Not Supported By Network."
For a start, you don't need wifi to send photos on a phone. That is down to the mobile network. It is, though, cheaper, as in free, if you use wifi .
I would be worried about that router though. The R6080 is one of the least capable in Netgear's range.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money.
A slow router will also limit the speed that your wifi can deliver. There too the top speed will be 100 Mbps.
