Flood404
Mar 20, 2017Aspirant
Netgear 2000v4 Firmware 1.0.0.66
The firmware for the WNR2000V4 1.0.0.66 is no good. I had it installed onto two of these routers. One was the DHCP to the modem the other provided an AP Wireless or Access Point for the public. ...
- Apr 04, 2017
Well its been a month and everything is working fine with the firmware 1.0.0.60. No more complaints about the computers or printers not working.
So if anyone has one of these just stick with the 1.0.0.60 firmware and they will be fine.
michaelkenward
Mar 21, 2017Guru - Experienced User
It isn't always necessary, but if you have problems after a firmware flash, you should reset the thing to factory settings.
- Flood404Mar 21, 2017Aspirant
I did everything by going to factory defaults. Then resetting up everything still happened.
I installed the older 1.0.0.60 firmware that fixed the SOAP API attack. Which I knew that one worked for over a year without issues.
Im going to wait and see if this issue happens again on 1.0.0.60 firmware.
